amynpenguin
Jul 18, 2021Tutor
RBR750 major issues after FW 4.6.3.7
Hoping someone can help here – I’ve already spent two hours on the phone with support to no avail. We have had the Orbi RBR750 router/2 satellite system for almost a year and experienced only very min...
Jul 18, 2021Guru - Experienced User
Anything in here of use?
Do both wired and wireless stop working?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
