amynpenguin
Jul 18, 2021Tutor
RBR750 major issues after FW 4.6.3.7
Hoping someone can help here – I’ve already spent two hours on the phone with support to no avail. We have had the Orbi RBR750 router/2 satellite system for almost a year and experienced only very min...
Jul 18, 2021Guru - Experienced User
Anything in here of use?
Do both wired and wireless stop working?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
5STRIPER
Jul 18, 2021Tutor
I scanned that thread and found nothing of help. Wired and wireless stopped working. I can't access my router, via Orbi app or web login, so can't verify channels. After factory reset I see in the Orbi app either "Orbi product not found" or "issues connecting with," with note to try disconnecting from mobile data, then try again. Doesn't work.
Modem is a Netgear Nighthawk CM1200, <Serial number removed>.
- FURRYe38Jul 19, 2021Guru - Experienced User
Set up the RBR from scratch using a wired PC and web browser.
Also un-install Orbi app and re-install it...
Do not post SN or MAC addresses in public forums.
Modem is a Netgear Nighthawk CM1200, <Serial number Removed>- 5STRIPERJul 19, 2021TutorOops. Who can edit out the SN or delete the whole comment? Will try what you recommend as Ethernet connection directly from modem to PC does work. Thanks.
