_marc_
Mar 07, 2022Aspirant
RBR750 mesh system constantly dropping Wifi
Hello. Our home wifi mesh system is constantly and randomly dropping the wifi signal. Here is the setup with 2 RBS750 satellites, both on V4.6.5.14: Hardware Version RBR750 ...
Mar 07, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You might review this and give it a try:
_marc_
The router is connected to a Spectrum D3.1 eMTA, DOCSIS 3.1 Advanced Voice Modem.
The router and satellites are spaced out with more than 30 feet between them, blue status lights.
Thanks for linking the thread to the new firmware. I'm going to take a look and give it a try. Will update this thread if it fixes my issues.
Thanks,
- FURRYe38Mar 07, 2022Guru - Experienced User
- FURRYe38Mar 12, 2022Guru - Experienced User
Any progress on this?
- _marc_Mar 21, 2022Aspirant
Nope... Still having the same issues, I've been disconnected maybe 10 times this morning. Makes my work very difficult.
I'm looking to replace the system with anything else but Netgear products at this point.
- FURRYe38Mar 21, 2022Guru - Experienced User
What FW is currently loaded?
