Jboogie17
Dec 29, 2023Aspirant
RBR750 NAT Stict
Hello, I have the AX4200 RBR750 wifi 6 system. Since getting this system 3 months my NAT type has been strict and this will not allow me to connect to play games. I have tried disabling the UPnP...
Dec 30, 2023Guru - Experienced User
What Game platform are you using? Xbox, PC or PS?
If you set up port forwarding configuration, you'll need to disable uPnP on the RBR. Generally you shouldn't need any PF configurations and uPnP can handle the ports needed automatically. What I use for my xboxes.
Jboogie17 wrote:
Hello,
I have the AX4200 RBR750 wifi 6 system. Since getting this system 3 months my NAT type has been strict and this will not allow me to connect to play games. I have tried disabling the UPnP and restarting and then reenabling the UPnP. I have tried port forwarding and turning the UPnP off. I have tried selecting the NAT filtering under the advanced WAN settings and setting it to OPEN and still, my NAT is strict. What can I do? I feel I have tried everything and have never had this issue with any other wifi system I've had. I am about to get rid of this system and get something else. Someone please help.
- CrimpOnDec 30, 2023Guru - Experienced User
The "devil is in the details". With port forwarding, essential steps include confirming that the router actually has a public IP address. Compare the IP address shown on the Orbi web administration Advanced Tab (in the upper right box)
with the IP address shown by a web port scanner, such as https://canyouseeme.org/
If they match, then the router has a public IP address.
Then confirm that the port are not only opened, but that they point to the correct device on the LAN by entering the port (or ports) that have been forwarded and verify that CanYouSeeMe reports the ports connecting to the device.
- Jboogie17Dec 30, 2023Aspirant
I have an Xbox One. The firmware version is V4.6.14.3_2.3.12. The modem is a Technicolor CVA4003TCH1 Cable Modem. I tried disabling the UPnP when I did the port forwarding and that didn't fix it so I deleted the port forwarding and turn back on the UPnP.
- FURRYe38Dec 30, 2023Guru - Experienced User
I believe your modem already has a built in router and wifi which would cause the Orbi system to not work right with uPnP or PF Configurations and your getting strict NAT on the xbox console.
Do you get same NAT status if you connect the console to the ISP modem?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
