Jboogie17
Dec 29, 2023Aspirant
RBR750 NAT Stict
Hello, I have the AX4200 RBR750 wifi 6 system. Since getting this system 3 months my NAT type has been strict and this will not allow me to connect to play games. I have tried disabling the UPnP...
Jboogie17
Dec 30, 2023Aspirant
I have an Xbox One. The firmware version is V4.6.14.3_2.3.12. The modem is a Technicolor CVA4003TCH1 Cable Modem. I tried disabling the UPnP when I did the port forwarding and that didn't fix it so I deleted the port forwarding and turn back on the UPnP.
Dec 30, 2023Guru - Experienced User
I believe your modem already has a built in router and wifi which would cause the Orbi system to not work right with uPnP or PF Configurations and your getting strict NAT on the xbox console.
Do you get same NAT status if you connect the console to the ISP modem?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
