gmcateer
Apr 06, 2022Follower
RBR750 Never worked correctly, opened tickets, now not supported - buh bye
Lack of support is amazing. They never could resolve my connection issues, this network has limped along and now our support is expired. Only option is to pay for more? Will never buy Netgear again. ...
Apr 06, 2022Guru - Experienced User
Lets see if we can help you here...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor, Smart Parental Controsl, or Traffic Meter enabled?
