Brigance
Apr 23, 2022Aspirant
RBR750 No connection/solid magenta
RBR750 dropped connection at 5:00am today with solid magenta ring. Rebooted multiple times to no avail. Hard line connection to modem from laptop is fine. Satellites show they are fine. Firmware...
- Apr 25, 2022Issue persists with CAT6 cabling.
Found a newer CAT5 in a stash of cables & used it after a factory reset of router & all satellites.
Factory reset & adding satellites back in one by one by using the app AND pressing sync on the router PRIOR to sync on the satellite seems to have solved the issue.
Apr 23, 2022Guru - Experienced User
Let us know if it continues after getting a CAT6 in place.
Brigance
Apr 25, 2022Aspirant
- FURRYe38Apr 25, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
