DivineEagle
Aug 22, 2024Aspirant
RBR750 No Longer Blocks Devices
My RBR750 system no longer blocks devices that are paused or associated with groups that are paused. When I go to the security settings, the only thing that shows up is Netgear Armor...it doesn't eve...
DivineEagle
I have not done a factory reset...wouldn't that require me to spend hours resetting up all the security configs that I have on it? I have done reboots.
It was working previously, but i have no idea whether or not a FW update caused the issue or not.
Aug 22, 2024Guru - Experienced User
Can save off a backup configuration to file, then try the factory reset and then load the back up to save time:
Also be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
