mmiller0
Sep 08, 2021Initiate
RBR750 no longer broadcasts 2.4ghz
A few days ago I noticed some of my 2.4ghz only smart home devices were having connectivity issues and after troubleshooting it appears that my Orbi RBR750 is no longer broadcasting a 2.4ghz network ...
- Sep 08, 2021
Has a full power OFF of the RBR with pulling the power adapter after the factory set for 1 minute been performed?
Sep 08, 2021Guru - Experienced User
- mmiller0Sep 08, 2021Initiate
Well geez that was easy. I had pulled the power but obviously not for long enough. I disconnected power from both the satellite and router for 2-3 minutes and now everything is working again. Thanks!
- FURRYe38Sep 08, 2021Guru - Experienced User
Awesomeness. Glad its working again.
Enjoy.
