rlborques
Feb 02, 2022Aspirant
RBR750 not able to connect new RBS750
I have a RBR750 router wired directly between a Spectrum modem and a LUXUL switch that feeds to ethernet ports around the house. The home has spray foam insulation in all walls (even internal) and so...
- Feb 02, 2022
What type CAT# cable are you using? CAT6 is commended.
You might review this as well. Current released FW has been giving users lots of problems:
Feb 02, 2022Guru - Experienced User
What is the brand and model # of the LAN switch your using?
Connect the RBS ethernet cable to the RBR temporarily, do they connect properly then?
RBS have to be connected behind the RBR when ethernet connected:
rlborques
One of two RBS750 described above is presently hard-wired to the RBR750 w/the same result. The switch model is XGS-1024S
- FURRYe38Feb 02, 2022Guru - Experienced User
- rlborquesFeb 02, 2022Aspirant
The house is wired with CAT5E, the two working satellites are on the same network wired the same way, the only difference between them is that they were setup last week along with the router. Wheras the other two were added this week. I will take a look at that firmware post. I am not opposed to running a manual update on all of them, I am familiar with that process.
You might swap locations with the working RBS to see if problem follows.
As long as FW version is same on everything, they should work. However could be cabling or switch issues.
Test each RBS out while in same room with the RBR and good working LAN cable to test them out.
