Rudini76
Aug 25, 2021Aspirant
RBR750 only 650 instead of 1gig Download speed
Hello I just bought a Orbi Mesh System For some reason I only get on the Orbi App only max 650 download speed upload is fine with 950 Not sure if there is a setting that is wrong or if the ro...
michaelkenward
Aug 26, 2021Guru - Experienced User
Measured how?
Wifi speeds depend on the wifi client more than the router and your Internet connection.
- Rudini76Aug 26, 2021Aspirant
Hey Michael
I used the Orbi App and before the nighthawk app.
I also used the speedtest app on my phone
But of course on the speedtest app i get even worse download speed.
I got a AT&T Fiber 1gig plan
- michaelkenwardAug 26, 2021Guru - Experienced User
Yup. As expected.
What's the firmware on the RBR750?
I assume that you haven't done things like enable QoS, a pointless exercise with 1 gig Internet. That eats processor power on the router, as does traffic metering.
Firmware is V4.6.3.7
And no I didnt do anything
Just followed the installation guide.
Honestly im not the brightest when it comes to Networkand network settings.
Guess I only can check on QoS when connected with my Laptop to the Router right ?
- FURRYe38Aug 27, 2021Guru - Experienced User
There is a known problem on v4 and using Orbi app and onboard speed test giving inaccurate results.
Use a wired PC conencted to the RBR and Ooklas installable speed test app and check speed there to compare.
Rudini76 wrote:
Hey Michael
