Rudini76
Aug 25, 2021Aspirant
RBR750 only 650 instead of 1gig Download speed
Hello I just bought a Orbi Mesh System For some reason I only get on the Orbi App only max 650 download speed upload is fine with 950 Not sure if there is a setting that is wrong or if the ro...
Rudini76
Aug 26, 2021Aspirant
Hey Michael
I used the Orbi App and before the nighthawk app.
I also used the speedtest app on my phone
But of course on the speedtest app i get even worse download speed.
I got a AT&T Fiber 1gig plan
michaelkenward
Aug 26, 2021Guru - Experienced User
Yup. As expected.
What's the firmware on the RBR750?
I assume that you haven't done things like enable QoS, a pointless exercise with 1 gig Internet. That eats processor power on the router, as does traffic metering.
- Rudini76Aug 26, 2021Aspirant
Firmware is V4.6.3.7
And no I didnt do anything
Just followed the installation guide.
Honestly im not the brightest when it comes to Networkand network settings.
Guess I only can check on QoS when connected with my Laptop to the Router right ?
- FURRYe38Aug 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Thanks FURRYe38
Totally new here so I appriciate the feedback and stirring me in the right direction.
- michaelkenwardAug 26, 2021Guru - Experienced User
Yes, but QoS is usually disabled by default.
Looks like the latest.
