GotProblemz
Jan 10, 2021Aspirant
RBR750 Orbi slow internet while streaming
Hi Some days ago I started to have problem with streaming shows on Netflix and other streamingservices. My internet speed is fine when messured. I have 500/500 internetspeed and a RBR750 Orbi Mes...
Jan 10, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, Pv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
GotProblemz
Hi
Nothing changed and everything has worked perfectly until now. The router is right next to the Smart TV.
No update was made recently.
We has a power outage some days ago. Can that affect something?
I cannot find all the settings you asked me to change.
No Factory set has been made.
- FURRYe38Jan 11, 2021Guru - Experienced User
Please give feed back to the questions presented...
