kplescia
Oct 12, 2023Follower
RBR750 ORBI WIFI 6 MESH GOES DOWN AT LEAST MONTHLY
The orbi Wifi 6 RBR 750 (2 satellites) loses internet and goes down at least monthly with magenta light, while my ISP Altice router/modem all-in-one fiber gateway (GR240BG) has internet connection. ...
Oct 12, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
kplescia wrote:
The orbi Wifi 6 RBR 750 (2 satellites) loses internet and goes down at least monthly with magenta light, while my ISP Altice router/modem all-in-one fiber gateway (GR240BG) has internet connection. The Orbi has the latest firmware v 4.6.14.3 and I have reset the Orbi time to time to default settings. The wireless internet works when changing to the Altice gateway, but I did notice it didn't work when I plugged desktop via ethernet cable. It only worked upon power cycling the gateway.
Is the Orbi just naturally temperamental to lose connection time to time to require power cycling, or could it be an issue with the fiber gateway I have? I am using 5e ethernet cable - would cat 6 make a significant difference?
