nsaul
Oct 28, 2024Aspirant
RBR750 Orbi without wifi, magenta light
I've had my mesh system for about 2 years now with no issue. My setup has been: - Spectrum ISP - 1 Arris Surfboard Modem (basement, not from the ISP) - 1 Orbi RBR750 Router (basement) - 2 Satelli...
- Oct 28, 2024
RESOLVED:
I ended up just factory resetting the whole mesh system and that seemed to fix the issue, very inconvenient solution but at least it worked.
nsaul
RESOLVED:
- FURRYe38Oct 29, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
