Stefan-M034
Jun 28, 2022Aspirant
RBR750 pink light every day
Hi! I installed a couple days ago the Netgear Orbi RBR750 and when it works, it really works good. The only thing is that the router show every morning when i wake up the pink light. I already r...
- Jun 30, 2022
After trying the suggested changes by ekhalil you might want update FW on the Orbi system at some point:
Stefan-M034 wrote:
Hi FURRYe38,
I have the Firmware version: V4.6.5.14 (the last version). The router is an TP-link Archer XR500v and i connected with the ethernet cable.
Stefan-M034
Jun 29, 2022Aspirant
Thanks!
The status under 'Lease Obtained' is 1 days, 0 Hours, 0 Minutes. For sure I can call the provider. What they need to change exactly with the 'WAN DHCP Lease Time'?
ekhalil
Jun 29, 2022Master
For me it's 0 Days, 1 Hour, 0 Minutes.
It will be great if the provider can reduce this lease time as much as possible. 1 day is quite long lease time, I guess that's why you have the issue every morning!
