Stefan-M034
Jun 28, 2022Aspirant
RBR750 pink light every day
Hi! I installed a couple days ago the Netgear Orbi RBR750 and when it works, it really works good. The only thing is that the router show every morning when i wake up the pink light. I already r...
- Jun 30, 2022
After trying the suggested changes by ekhalil you might want update FW on the Orbi system at some point:
Stefan-M034 wrote:
Hi FURRYe38,
I have the Firmware version: V4.6.5.14 (the last version). The router is an TP-link Archer XR500v and i connected with the ethernet cable.
Jun 29, 2022Guru - Experienced User
Stefan-M034 wrote:
Hi!
I installed a couple days ago the Netgear Orbi RBR750 and when it works, it really works good. The only thing is that the router show every morning when i wake up the pink light. I already reset the router and buy CAT6a cables. Those things don't fixed te problem.
When i reboot the router everything works again. I checked also if i had internet by the provider self and yes that internet works when the Orbi router doesn't work.
What i can do more the fix this?
Thanks in advance!
Stefan-M034
Jun 30, 2022Aspirant
Hi FURRYe38,
- FURRYe38Jun 30, 2022Guru - Experienced User
Stefan-M034 wrote:
Hi FURRYe38,
- Cinemagic310Feb 04, 2023GuideI am not seeing the 4.6.5.14 fw available on my web access or app. should I just wait for it?
