dbrb2
Jan 10, 2022Apprentice
RBR750 port forwarding rule
I have set up my Orbi RBR750 and, although the app seemed quite buggy, after a few itterations it worked as desired. However, I am struggling to find a way to set up port forwarding that specifi...
Jan 10, 2022Guru - Experienced User
Something to review:
https://kb.netgear.com/31069/How-do-I-configure-port-forwarding-on-my-Orbi-system
dbrb2
Thanks - yes, I found that.
That allows for inboudn rules, but does not seem to allow for more specific rules - allowing that forward ONLY for a given remote external IP
It might be that this simply isn't a feature provided by the Orbi, though it seems a bit odd given if that is the case, given it is a fairly common requirement.
The unit also does not seem to manage local dns...? So if I have a device with hostname "thing" and I try to ping it, the ORBI will not resolve that. Instead I wouod have to rely on mDns
I can work around both of these issues by using the Orbi in AP mod ans using openWrt to do my routing, but again local DNS resolving seems a very basic feature, so I wonder whether perhaps I have just missed the setting....
