jixxer
Jun 03, 2024Aspirant
RBR750 port forwarding stopped working
Port forwarding seemed to have stopped working on my router for my VPN server using port 51820. It is on the latest FW V7.2.6.31, it was working after update but suddenly stopped and hasn't worked si...
CrimpOn
Jun 03, 2024Guru - Experienced User
Port forwarding relies on internet devices connecting with the correct public IP address (which is why the OpenVPN server bundled into Orbi routers requires creating a DDNS URL which the router keeps synchronized with any changes that the Internet Service Provider (ISP) made to the public IP address.
Can you verify that devices attempting to connect are being directed to the current public IP address of the router?
Which VPN server has been deployed on the LAN?
jixxer
I'm running a WIREGUARD server through a gl-inet brume 2 router which is connected to NG router on the WAN port and using DDNS.
- FURRYe38Jun 03, 2024Guru - Experienced User
What happens if you put this "gl-inet brume 2 router" IP address it gets from the RBR into the RBRs DMZ as a quick test?
- CrimpOnJun 03, 2024Guru - Experienced User
I am confused. The brume 2 supports both OpenVPN and Wireguard VPN in both Client and Host mode. The Client mode (for both VPN protocols) bundles every device on the LAN side into a VPN tunnel directed to one of these VPN providers:
The brume 2 supports VPN Host mode for both OpenVPN and Wireguard. Wireguard Host listens on port 51820 while OpenVPN Host listens on port 1194. Since the brume 2 is connected directly to the Internet Service Provider (ISP), there is no reason to implement port forwarding on the Orbi router, which is connected on the LAN side of the brume 2.
That leads to the important question: What 'mode' is the RBR750 in? ('router' or 'access point'?)
If the Orbi is in 'access point' mode and the brume 2 public IP address matches the IP returned by DDNS, then Wireguard Host should function correctly.
If the Orbi is in 'router' mode, I do not understand how Wireguard Host can connect with any device on the Orbi LAN. In 'router' mode, the Orbi uses Network Address Translation (NAT) to make it appear that every device on the Orbi LAN has the same IP address (the WAN address of the Orbi router).
So:
- Are we absolutely certain that the WAN IP address of the brume 2 matches the IP returned by DDNS, and
- What 'mode' is the RBR750 now in?
- jixxerJun 03, 2024Aspirant
The Orbi is the one directly connected to the ISP not the brume thats why PF is needed for the brume to access the WIREGUARD server.
- CrimpOnJun 04, 2024Guru - Experienced User
My bad. Should have realized that "on the WAN port" is ambiguous. With the brume WAN port connected to one of the Orbi LAN ports, what is connected to the brume LAN port?
The brume User Guide is pretty specific. (https://docs.gl-inet.com/router/en/4/interface_guide/wireguard_client/ )
- The Wireguard Client mode, which bundles all devices on the brume LAN side into a tunnel to one of the Wireguard servers, does not require (a) a public IP address or (b) port forwarding. That is because the Wireguard Client is opening the tunnel.
- The Wireguard Server (Host) is the feature that requires public IP and port forwarding because a client device on the internet somewhere is attempting to open a VPN tunnel to the server running on the brume.
If it has been confirmed that the public IP address produced by the DDNS provider matches the public IP address on the Orbi router, then it might be useful to perform an experiment to determine whether the Orbi router is actually performing port forwarding. For example, forward that port 51820 to some other device on the Orbi LAN that will respond to internet connections. My "go to" devices are:
- An Epson printer which has a simple web interface. (port 80)
- A Raspberry Pi running Pi-Hole (also port 80)
Change the port forwarding rule to external port 51820 to internal port 80 on the LAN IP address of the target device.
Using a device not on the Orbi LAN (smart phone with WiFi disabled is quick and easy), open a web browser to:
- Public IP of Orbi router (i.e. http://<public IP> )
- The DDNS URL ( i.e. http://<DDNS URL> )
If the test device responds, then the Orbi port forwarding process is working.
What is the primary purpose for running the Wireguard server?
