jixxer
Jun 03, 2024Aspirant
RBR750 port forwarding stopped working
Port forwarding seemed to have stopped working on my router for my VPN server using port 51820. It is on the latest FW V7.2.6.31, it was working after update but suddenly stopped and hasn't worked si...
jixxer
I'm running a WIREGUARD server through a gl-inet brume 2 router which is connected to NG router on the WAN port and using DDNS.
Jun 03, 2024Guru - Experienced User
What happens if you put this "gl-inet brume 2 router" IP address it gets from the RBR into the RBRs DMZ as a quick test?
