jixxer
Jun 03, 2024Aspirant
RBR750 port forwarding stopped working
Port forwarding seemed to have stopped working on my router for my VPN server using port 51820. It is on the latest FW V7.2.6.31, it was working after update but suddenly stopped and hasn't worked si...
Jun 03, 2024Guru - Experienced User
Had this been working on prior version of FW?
Was prior version v.21?
- jixxerJun 03, 2024Aspirant
Yes it was working on prior FW which I also tried rolling back to and it still doesn't work. So might just be a brick now
- FURRYe38Jun 05, 2024Guru - Experienced User
If you rolled back to prior FW version, did you factory reset the system and setup from scratch and check port forwarding?
