jixxer
Jun 03, 2024Aspirant
RBR750 port forwarding stopped working
Port forwarding seemed to have stopped working on my router for my VPN server using port 51820. It is on the latest FW V7.2.6.31, it was working after update but suddenly stopped and hasn't worked si...
Jun 03, 2024Guru - Experienced User
Had this been working on prior version of FW?
Was prior version v.21?
jixxer
Yes it was working on prior FW which I also tried rolling back to and it still doesn't work. So might just be a brick now
- FURRYe38Jun 05, 2024Guru - Experienced User
If you rolled back to prior FW version, did you factory reset the system and setup from scratch and check port forwarding?
- jixxerJun 05, 2024Aspirant
Seems like something changed on my ISP where they were giving me a private IP instead of public.
Solution
Set DMZ and PF on modem to router, then PF from router to brume.
Thanks for all the help!
- CrimpOnJun 05, 2024Guru - Experienced User
I have been using the OpenVPN server bundled with the Orbi router for years. My guess is that investing $85-$90 in a bume 2 VPN device is some combination of:
- Wanting the option to run a VPN Client on the LAN rather than install VPN software on multiple devices, and
- Wireguard is generally believed to be more efficient than OpenVPN, but not supported by Netgear on Orbi routers.
To see "what's going on", I installed Wireguard server on a Raspberry Pi. (relatively painless) and forwarded port 51820 to the Pi. Generated a Wireguard client configuration and used the QR code method to install it on a smartphone. (Much more convenient than configuring OpenVPN on devices with cameras.) Hot Damn! I now have two VPNs that can be used to connect to the Orbi LAN from the internet. Not particularly impressed with the debugging/log information generated by the Wireguard app for Android. May check out Wireguard for Windows laptop.
Thanks for bringing attention to this curious VPN device.
