jixxer's avatar
jixxer
RBR750 port forwarding stopped working
Port forwarding seemed to have stopped working on my router for my VPN server using port 51820. It is on the latest FW V7.2.6.31, it was working after update but suddenly stopped and hasn't worked si...
  • jixxer's avatar
    jixxer
    Jun 05, 2024
    FURRYe38 CrimpOn
    Seems like something changed on my ISP where they were giving me a private IP instead of public.
    Solution
    Set DMZ and PF on modem to router, then PF from router to brume.
    Thanks for all the help!
