CargoCult
Oct 23, 2023Guide
RBR750 Port Forwarding through another router
XFinity cable modem (Technicolor model cgm4140com) with ethernet attached RBR750 in router mode. Should it be possible to forward a port for a device with a static ip address connected to the RBR...
- Oct 24, 2023
CargoCult wrote:
But I'm not sure how to connect the external IP of the Xfinity modem through the Orbi's IP, to my device. Is this possible?
Yes, this may be possible (although tedious). The key is having access to the Internet Service Provider (ISP) device. Since Xfinity recommends using their 'app' to install the CGM4140COM, one might infer that you can indeed access the management interface. Once logged into it, then you can forward the port through to the Orbi RBR750 IP.
As an experiment, I have forwarded a port (I chose port 80 for the test) through three routers:
- Router 1 forwards port 80 to the WAN IP of router 2.
- Router 2 forwards port 80 to the WAN IP of router 3
- Router 3 forwards port 80 to the LAN IP of the web server
Connect to the Public IP of Router 1 and the connection goes through three routers to the web server.
It's a bit confusing. The device is described on this Xfinity page:
https://www.xfinity.com/support/articles/broadband-gateways-userguides
While many of the products have distinct links to download the user guide, there is no link to a guide for this product. The table at the bottom of the page claims there indeed is a Gateway and Network Management Tool:
There is another alternative: replace the CGM4140COM with an ordinary modem compatible with Xfinity.
This web page provides a method to discover which cable modems are compatible with Xfinity:
https://www.xfinity.com/support/devices/#unauth
Netgear lists several modems as being compatible with Xfinity:
https://www.netgear.com/home/wifi/modems/
Two in their description mention Xfinity Voice. The others mention Xfinity when looking at the actual product description.
CrimpOn
Oct 24, 2023Guru - Experienced User
CargoCult
Oct 24, 2023Guide
Thanks for this advice - I'll have a stab at doing the double port forward and post back.
Thanks again for the insight and for trying it out!
