Girl
Feb 14, 2024Aspirant
RBR750 Quit working within days of firmware update
I have an Orbi RBR750 Wi-Fi 6 mesh system. My Orbi would not update to the new firmware so I contacted support and they helped me download the new firmware 7 something. Orbi firmware 4 something wa...
Girl
I downloaded the latest firmware version which is 7 something.
I don't have a modem from my internet provider. My Orbi RBR750 Mesh system with two satellites run my internet. Our internet provider is Brightspeed (formerly Century Link). We have fiber internet and my house is 2,000 sq feet. I have
had this RBR750 mesh system since May 2021 and it has worked seamlessly until now. I do have the correct cable although I don't know if it is a cat 6. I am a novice at best. I know how to make sure the cables are connected correctly and how to reset the Orbi if that needs to be done. I cannot log on to 192.168.1.1 with the wired computer.
Thanks for your input.
Feb 14, 2024Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers ONT the NG router is connected too?
If you disconnect the RBR from the ONT, press the reset button in back for 15 seconds, then give 1 minute, does the setup wizard page appear in the web browser with the Orbi app sign on this page? At the bottom is a link to begin the setup routine with the PC and web browser.
You can follow this for review:
- GirlFeb 14, 2024Aspirant
I don't know anything about Mfr and model# of the Internet Service Providers ONT the NG router. I do not have a piece of equipment inside my houise associated with the Internet Service Provider. Sorry! As I said I am a novice. The only
equipment I know about is the ORBI RBR 750 router and two satellites. There may be some type of equipment outside of my house that I don't know about.
- FURRYe38Feb 14, 2024Guru - Experienced User
Ok, if the ONT is outside, we can only presume its just a ONT and no built in router or wifi here. If at some point, could get someone to help you with that and post that back here, would be good. Need to confirm brand and model if possible.
For that size of home, the main router unit, RBR, and just 1 RBS would be needed. Having two RBS maybe too much and could also be causing problem. https://youtu.be/UR0viMLISz4
Lets power OFF one RBS for now. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️- GirlFeb 14, 2024Aspirant
Thank you! I will ask my husband to look at see if he sees a piece of equipment somewhere outside. I have turned off one of my satellites.
I do really appreciate your time!
