BlackbirdSR71
Feb 13, 2021Follower
RBR750 RBS750 Firmware Update 3.2.17.12
Hi, I have a RBR750/RBS750 setup running with firmware V3.2.16.22. Recently I noticed that on the Negear support web site, it indicates there is a new firmware version 3.2.17.12 available. It will...
Feb 23, 2021Guru - Experienced User
Any progress on this?
BlackbirdSR71 wrote:Hi,
I have a RBR750/RBS750 setup running with firmware V3.2.16.22. Recently I noticed that on the Negear support web site, it indicates there is a new firmware version 3.2.17.12 available. It will fix issue like not able to run speed test from the app. However, when I try to do a firmware check from orbilogin web page, it always says I have the latest firmware. Anyone have any idea what is happening here? (I avoid doing it manually which requires to download the firmware and then apply it to the satellite first and then the router).
- vajimFeb 24, 2021Master
