TheDood
Jul 21, 2022Follower
RBR750 RBS750 Satellites will not sync
2 RBS750 satellites both went offline and then would not sync back to the RBR750 router. After performing all the troubleshooting steps (factory resets, connnecting to satellites via ether, syncs, et...
- Jul 21, 2022
Sounds like the RBS updated FW and the RBR didn't. Should not be happening like this but glad you got it working.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 21, 2022Guru - Experienced User
Enjoy. 📡
