narutokaya
Apr 21, 2025Aspirant
RBR750 RBS750
Ive reset the router and satellites back to factory settings and still cannot get the satellites connected to the network. Even connecting a CAT6 from the satellite to the router directly, it is stil...
CrimpOn
Apr 21, 2025Guru - Experienced User
(It appears that this post has been 'moved' from the Orbi WiFi5 forum to this Orbi WiFi6 form - the correct forum for the 750 product.)
When a 'package' is created at the factory, consisting of one router and one or more satellites, the factory configures them as a system so that customers can take them "out of the box" and they will function with absolutely no configuration of any kind. (as long as the ISP does not require a user ID and password to connect, which most do not.)
As any previous posts on this topic appear to have disappeared, it might be useful to know:
- Were these Orbi units purchased new as a 'package' (in one box)?
- Were they operating as a system before being Factory Reset?
If not, it might be worth following the "Add Orbi Satellite" procedure on the web interface. Bottom menu item on the Basic Tab.
