teng824's avatar
teng824
RBR750 reboot problem
Hi , i got this problem when i log in to 192.168.1.1 to reboot my Orbi router RBR750 . After i press YES , it stuck at the page and the router never reboot . I close the browser and try log in again to 192.168.1.1 but no responce . I have to unplug the power and plug it back to make it reboot . Any solution for this ? Thanks
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Try a different browser? IE11, MS Edge or Firefox...
    Thank you.
  • FURRYe38's avatar
    • teng824's avatar
      teng824
      Current firmware V3.2.18.1_1.4.14
      Huawei modem
      Previously dont have this problem
      • FURRYe38's avatar
