claudiut's avatar
claudiut
Apprentice
Jan 05, 2023
RBR750 regular reboot or not?
Hello,   I have a RBK753 system (RBR750 router and 2 x RBS750 satellites) and it's been pretty stable for the last while after a long period of issues with bad firmware (v4.6.5.14) I'm currently ru...
  • FURRYe38's avatar
    Jan 05, 2023
    Regular reboots should not be needed. If there needed then something needs to be checked. Routers should not need any reboots for normal operation.
    I've had my 7 series online for going on a week now on FW v.3 and is working just fine.
