TJ_Ho
Mar 21, 2025Aspirant
RBR750 regular reboot required since firmware update
I find that I constantly have to reboot the router since firmware updated. V7.2.6.31_5.0.24 Any suggestions?
- Mar 21, 2025
Hello TJ_Ho,
Welcome to the NETGEAR Community!
I understand that you are having reboots with the FW v7.2.6.31 on your RBR750. Please update to the most recent FW release v7.2.7.15. Please be sure to update the satellite first.
Please navigate to the link below to manually download the FW v7.2.7.15:
https://kb.netgear.com/000066598/RBR750-RBS750-Firmware-Version-7-2-7-15
Please follow the directions in the video embedded in the link below to successfully update your satellites:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteNavigate to the link below for additional update instructions for your Orbi system:
Best,
Kevin
Community Team
KevinLiT
Mar 21, 2025NETGEAR Moderator
Hello TJ_Ho,
Best,
Kevin
Community Team
TJ_Ho
I was able to successfully update the satellite to the new firmware. Now when I go to manually update the router, RBR is no longer an option. Only shows RBS.
On the auto update tab it shows both with different firmware.
