Charlie53463
Jun 08, 2023Aspirant
RBR750 repeatedly losing wifi connection
This looks like a common problem, not happy given how much i've paid... trying to decide whether to return as faulty. Firmware: v4.6.14.3 SSID: unique name. Same name across all bands. Loc...
Jun 09, 2023Guru - Experienced User
I know materials is going to be problematic. Brick isn't great for wifi.
Do you get any good or poor signal at the garage RBS if you turn OFF the kitchen RBS?
Or try turning OFF the garage RBS and leave the Kitchen RBS ON then test roaming?
Charlie53463
Jun 09, 2023Aspirant
And I've just tried video call with my iPhone 12 and it lost connection walking from the house towards the garage.... Isn't picking up the garage signal at all now...
- Charlie53463Jun 09, 2023AspirantI've had to turn wifi off and forget connection and re join...
- FURRYe38Jun 09, 2023Guru - Experienced User
Would you enable debug logging on the RBR and do that same walk thru the house test again?
Then save off the logs and upload to a cloud service.
NG would like to review the logs for this.Is Auto Join enabled or disabled on the phone? It should be enabled.
- Charlie53463Jun 09, 2023AspirantYes will do. Thanks again for your help so far.
- Charlie53463Jun 09, 2023AspirantYes it is
- Charlie53463Jun 09, 2023AspirantActually I've had the logs turned on... It's only showing a whole bunch of [DHCP IP:192.168.1.10 etc to MAC address xx:cc:xx etc
Probably one every minute... But different LAN addresses.
I do have fixed IP setup up for most of my network attacked devices.
It does have a few 192.168.2.2 and 2.3 messages too... Assume that's the satellites... But strange as the main router is 192.168
1.1 - Charlie53463Jun 09, 2023AspirantI've got the logs on One Drive ready to share. It's got a load of Mac addresses in there so probably not best to post openly.
Send me a PM if you like.
i've stripped out the MAC addresses...
[Admin login] from source 192.168.1.11, Friday, Jun 09,2023 19:53:03
[DHCP IP: (192.168.1.11)] to MAC address xxxxx, Friday, Jun 09,2023 19:51:57
[DHCP IP: (192.168.1.18)] to MAC address xxxxx, Friday, Jun 09,2023 19:51:38
[DHCP IP: (192.168.2.3)] to MAC address xxxxx, Friday, Jun 09,2023 19:43:04
[DHCP IP: (192.168.1.16)] to MAC address Axxxx, Friday, Jun 09,2023 19:42:43
[DHCP IP: (192.168.1.16)] to MAC address xxxx4, Friday, Jun 09,2023 19:42:19
[DHCP IP: (192.168.1.10)] to MAC address x4, Friday, Jun 09,2023 19:39:32
[DHCP IP: (192.168.1.18)] to MAC address xxxD, Friday, Jun 09,2023 19:38:24
[DHCP IP: (192.168.2.2)] to MAC address xxxx5, Friday, Jun 09,2023 19:37:34
[DHCP IP: (192.168.2.2)] to MAC address xxxx5, Friday, Jun 09,2023 19:36:52
[DHCP IP: (192.168.2.2)] to MAC address xxxx5, Friday, Jun 09,2023 19:35:51
[DHCP IP: (192.168.2.2)] to MAC address xxxx, Friday, Jun 09,2023 19:35:21
[DHCP IP: (192.168.1.13)] to MAC address xxxx, Friday, Jun 09,2023 19:34:23
[DHCP IP: (192.168.1.13)] to MAC address xxxxxF, Friday, Jun 09,2023 19:33:26
[DHCP IP: (192.168.1.16)] to MAC address Axxxxx4, Friday, Jun 09,2023 19:32:28
[DHCP IP: (192.168.2.3)] to MAC address xxxxx, Friday, Jun 09,2023 19:32:08
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:30:25
[DHCP IP: (192.168.2.2)] to MAC address xxxxxx, Friday, Jun 09,2023 19:29:58
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:28:46
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:28:31
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:28:27
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:28:25
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:28:18
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:27:46
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:25:35
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:16:19
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:10:33
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 19:01:19
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:55:36
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:55:32
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:46:46
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:40:30
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:31:58
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:27:38
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:25:29
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:10:27
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:10:06
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:09:43
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:08:23
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:08:14
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:08:00
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:02:20
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 18:01:58
[DHCP IP: (192.168.1.16)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:58:16
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:58:09
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:57:52
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:57:16
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:52:51
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:49:04
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:48:30
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:47:56
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:37:51
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:30:58
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:22:50
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 17:07:49
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:52:48
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:40:24
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:39:48
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:39:29
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:37:47
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:36:48
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:33:29
[DHCP IP: (192.168.1.19)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:28:45
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:23:30
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:22:46
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:21:47
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:07:45
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:06:47
[DHCP IP: (192.168.1.4)] to MAC address xxxxxxx, Friday, Jun 09,2023 16:01:44
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:52:44
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:51:47
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:37:43
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:36:48
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:22:42
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:22:09
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:20:31
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 15:07:41
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:52:40
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:41:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:37:39
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:26:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:22:38
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:11:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 14:07:37
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:56:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:52:36
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:41:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:37:35
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:26:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:22:34
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:11:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:07:33
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:00:19
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 13:00:05
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:56:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:52:32
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:41:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:37:30
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:26:14
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:22:29
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:11:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 12:07:28
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:56:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:52:27
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:44:18
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:41:13
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:37:26
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:31:08
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:22:25
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 11:07:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 10:52:22
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 10:37:21
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 10:22:20
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 10:07:19
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 09:52:18
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 09:37:17
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 09:22:16
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 09:07:14
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:54:15
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:54:04
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:53:47
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:53:23
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:52:59
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:52:12
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:37:11
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:26:22
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:25:41
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:24:20
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:22:09
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:20:13
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:18:35
[DHCP IP: (192.168.1.15)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:17:14
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:15:17
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 08:07:07
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:58:49
[DHCP IP: (192.168.1.7)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:55:39
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxxx, Friday, Jun 09,2023 07:55:06
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:53:09
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:52:06
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:45:08
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:37:05
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:29:56
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:22:41
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:22:04
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:18:19
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:16:04
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:15:03
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:14:57
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:14:45
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:14:41 - Charlie53463Jun 09, 2023Aspirant
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:13:36
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:13:05
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:11:27
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:04:38
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 07:04:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:56:26
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:49:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:41:25
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:34:25
[Dynamic DNS] host name ccccc.ddns.net registration successful, Friday, Jun 09,2023 06:30:47
[Dynamic DNS] host name cccccc.ddns.net registration failure, Friday, Jun 09,2023 06:30:15
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:26:23
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:23:21
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:21:57
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:19:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:11:22
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 06:04:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:56:21
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:49:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:41:20
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:34:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:26:19
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:19:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:11:18
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 05:04:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:56:17
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:49:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:41:16
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:34:24
[DHCP IP: (192.168.1.19)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:28:45
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:26:14
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:19:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:11:13
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:04:24
[DHCP IP: (192.168.1.4)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:01:43
[DHCP IP: (192.168.1.5)] to MAC address xxxxxxx, Friday, Jun 09,2023 04:01:43
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:56:12
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:49:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:41:10
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:34:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:26:09
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:19:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:11:08
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 03:04:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:56:07
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:49:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:41:06
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:34:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:26:05
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:19:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:11:04
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 02:04:24
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:56:03
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:49:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:41:01
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:34:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:26:00
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:19:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:10:59
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 01:04:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:55:58
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:49:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:40:57
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:34:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:25:56
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:19:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:10:55
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Friday, Jun 09,2023 00:04:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:55:54
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:49:23
[DHCP IP: (192.168.1.14)] to MAC address xxxxxx, Thursday, Jun 08,2023 23:49:05
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:40:53
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:34:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:25:52
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:19:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:10:51
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 23:04:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:55:50
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:49:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:40:49
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:34:24
[DHCP IP: (192.168.1.17)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:31:48
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:25:47
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:19:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:10:46
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 22:04:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:55:45
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:49:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:40:44
[DHCP IP: (192.168.1.6)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:34:27
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:34:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:25:43
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:19:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:10:41
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 21:04:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:55:41
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:49:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:40:40
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:34:23
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:25:40
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:24:39
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:10:39
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 20:09:58
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:56:32
[DHCP IP: (192.168.1.7)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:55:39
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:55:37
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:55:06
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:54:19
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:55
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:55
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:55
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:54
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:50
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:21
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:08
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:05
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:53:02
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:57
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:55
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:54
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:52
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:49
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:49
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:48
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:43
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:43
[DHCP IP: (192.168.1.13)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:35
[DHCP IP: (192.168.1.12)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:52:02
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:51:55
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:51:42
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:51:32
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:47:15
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:47:03
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:46:21
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:46:10
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:46:00
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:45:58
[DHCP IP: (192.168.1.10)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:39:33
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:38:16
[DHCP IP: (192.168.2.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:37:42
[DHCP IP: (192.168.1.7)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:37:19
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:36:46
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:50
[DHCP IP: (192.168.1.4)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:40
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:35
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:16
[DHCP IP: (192.168.2.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:15
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:08
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:35:06
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:59
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:59
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:57
[DHCP IP: (192.168.1.11)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:55
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:48
[Time synchronized with NTP server] Thursday, Jun 08,2023 19:34:45
[Internet connected] IP address: 81.101.xx.xx, Thursday, Jun 08,2023 19:34:44
[DHCP IP: (192.168.1.2)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:38
[DHCP IP: (192.168.1.3)] to MAC address xxxxxxx, Thursday, Jun 08,2023 19:34:38
[Initialized, firmware version: V4.6.14.3_2.3.12] Thursday, Jun 08,2023 19:34:37 - FURRYe38Jun 09, 2023Guru - Experienced User
Seeing lots of repeating DHCP requests.
Do you have Guest Network enabled as well?
What all devices do you have connected currently.
And for info, my S20 Phone is the 192.162.2.3 device - I tried using changing to a guest-wifi to see if that made any difference... it still has the same dropouts.
Ok, got it. Good test.
I've got a private message from one of the Netgear engineers... and have captured the detailed log files whilst the drop-out occurred - sent those over. Will see what they reckon is going on.
Good. Glad there on it.
- FURRYe38Jun 18, 2023Guru - Experienced User
Lets try some beta FW:
https://www.surveymonkey.com/r/G32BGFF
- FURRYe38Nov 06, 2023Guru - Experienced User
Was there any progress on this?
