JimmyDisco
Jun 07, 2024Aspirant
RBR750 Router - stopped working
Hi, the router front light is staying on. Says it is online on app and can do speed test however is not working when attempt to load online content. It appears to have full strength when wifi is selec...
Jun 07, 2024Guru - Experienced User
What color is the front LED on the RBR?
Are you able to access the RBRs web page at 192.168.1.1 with a wired PC and web browser at all?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- JimmyDiscoJun 10, 2024Aspirant
Hi,
Thanks.
The LED bar is white.
I do not have the facility to connect with a wired pc
We have 21 satellite and it has not been an issue.
We did the power off process and it was not resolved.
I attempted to update the firmware before posting this on the forum the other day and it said to try again later as could not be done.
The Orbi app no longer opens as says 'we can't find your Orbi'
Hard reset and new set up has been done
Anything else we can try?
- FURRYe38Jun 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the size of your home? Sq Ft?Might as a friend or neighbor for help with a wired PC or wired laptop to help you on this.
- JimmyDiscoJul 07, 2024Aspirant
We do not have access to a computer with an ethernet input.
Can't say re firmware version as app was not working with router not working.
Have purchased a new kit (RB760) as could not resolve the issue and seems Netgear have discontinued this router so can't replace the individual item.
Do you know if I can source a RB750 from Netgear or another source?
To me, seems a strange design for the satellites to not be compatible with other routers, eg 750 & 760.
Thanks for your help.
- FURRYe38Jul 07, 2024Guru - Experienced User
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Try a 30-30-30 reset on the RBR750.
Might try Amazon, Ebay or Shopgoodwill
