R0ck3tman
Jun 11, 2021Aspirant
RBR750 router restarting randomly
I have the RBK753 with the RBR750 and two satellites. All seems to be working well except for reboots of the router that seem to happen randomly. I'll be working on something and all of a sudden my i...
Jun 14, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
R0ck3tman wrote:I have the RBK753 with the RBR750 and two satellites. All seems to be working well except for reboots of the router that seem to happen randomly. I'll be working on something and all of a sudden my internet stops working. When I check the router it gives me the router password reset page. If I wait a few minutes the normal management page comes up and my internet starts working again. The Router is plugged into a surge protector with other devices that are not having any issues. So it is not a power issue. I can't seem to find any logs to tell me what is happening. The current firmware is V3.2.18.1_4.14. It is getting very frustrating. It just happened twice in the last hour.
On a side note, I've noticed that there are not very many WIFI settings that I can change such as beamforming even in the Advanced settings. Is that normal for this router?
- R0ck3tmanJun 15, 2021Aspirant
Thanks for the reply. The modem is my own and is a Netgear CM700. It seems to be ok when this happens as I can log in to it just fine. The home is 4900 square feet. I have the Router and one satellite on the main floor the satellite is about 30 ft from the router. But, as I stated, it doesn't seem to be the satellite disconnecting but the router is rebooting. I was hoping to get some guidance on how to get more logs from the router to determine why it is rebooting.
- FURRYe38Jun 15, 2021Guru - Experienced User
If you turn OFF the RBS, does the RBR still exhibit this problem?
Has a full factory reset and setup from scratch of the RBR and RBS and power OFF of the ISP modem been performed since last FW update?
What kind of cable are you using between the RBR and ISP modem? CAT6 is recommended.
I haven't tried disconnecting the Satellite and seeing if it exhibits the problem. I'm not sure when the last firmware update was and I haven't done a full factory reset because of the hassle of logging everything back into the wifi. The cable is a cat 6 cable. and there are a couple of neighbors but not many. But, I don't think the cable, neighbors, or turning off the satellite are going to be causes of the router rebooting randomly.
