pbojja
Sep 16, 2022Tutor
RBR750 running firmware 4.6.9.11 disconnects from Internet
I have a RBR750 which recently updated to firmware V4.6.9.11, it is connected to two RBS750 satellites (running the same firmware version). I've observed the RBR750 router doesn't any warning light o...
Sep 18, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
