iZGuasZfIKAY
Oct 28, 2022Aspirant
RBR750 satelitte issues
I have one satellite that has no devices showing on it. The orbi app shows it is connected and if sync button is pressed the light turns blue as suggested. The satellite is very close to a couple of ...
iZGuasZfIKAY
3,000 sq ft. router in Basement Sat #1 in kitchen Sat 2 (not picking up devices) at end of house 50 feet from Sat 1
Oct 28, 2022Guru - Experienced User
For that size of home, you really only need 1 RBS.
If you have two, try turning down the power on the RBR from 100% to 50% and see if this helps steer some devices to other RBS: Under Advanced Tab/Advanced Settings/Wireless Settings
