nicetranslady's avatar
Jan 04, 2022
RBR750 Satellite flapping between router and satellite for backhaul
Hardware Version: RBR750, Firmware VersionV4.6.5.14_2.0.54, Router Mode, 3 Satellites.
I had a problem where random satellites would go orange, then flash white and connections would drop all over the place. This happened almost continuously for a few days.
I switched everything off. EVERYTHING. Powered back up in this order: ISP Router, Orbi Router (updated firmware), Orbi Satellites (updated firmware), and then all consumer devices. Everything connected back. Lovely.
All satellites connect, backhaul seems fine and connections not dropped. However, one of the satellites is now continuously flapping between backhaul to the router and another satellite. Light goes blue, flashes white, I check the topology, it changes, then the light goes blue and back to step one.
I do not care if it connects "Star", or "Daisychained" - I just want it to pick one and stick to it. Is it possible to log in to a satellite and choose an upstream device to prefer? I can't find an option to turn off daisy-chaining, as explained on a slightly different thread.
NB. The status never stops being green in the app. Occasionally it drops to 2.4Ghz, but I don't have time to look at that for long as it flaps again.
Thank you.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • nicetranslady's avatar
      nicetranslady
      Guide
      I've no idea of the sq.ft. area of the house, but there are brick walls all over the place and it's L-shaped. The signal between satellites goes through two external double-brick walls and two internal walls (one lath and plaster, the other plasterboard), and the same plus a brick stairwell and a ceiling/ floor when it decides the router is a better bet. The straight-line distance is around 30ft and 45 ft respectively. Some home automation, an Echo 5, the boiler control and a SONOS speaker had flaky connections out that way, which is why this satellite has been installed-modifying the thermostat temperatures used to fail all the time. It doesn't now. Calls also dropped as you enter the room below. Very annoying!
      I did not reconfigure from a factory reset after the latest updates as frankly, that as a requirement is insane. I use a /30 subnet to uplink to my router, and quite a lot of reservations-for home automation/ IoT hubs and various other bits of config. Why would I consider resetting to factory, unless the software is shoddy?
      Sky Fibre broadband router via ONT, using their router with all IPv6 configuration turned off, all Wi-Fi and any other service turned off with the exception of ALG/SIP, DNS, NTP, routing and a LAN port configured to use the other address in the /30.
      2.4Ghz: Auto
      5Ghz: 36
      I can see only 3 other SSIDs when I scan.
      I assume that I'd only lower the 5Ghz radio, we connect from 90ft down the garden to the satellite, which probably uses 2.4Ghz). I need to keep that.
      I'll try the radio output reduction now and see if that helps. I could also look to move the satellite that is flapping further away and down another floor and see if the backhaul still connects at 5Ghz. That would be about 60ft away then.
      Thank you.
      • FURRYe38's avatar
        Might try swapping RBS and see if the problem follows or remains at this one locations.
        Is there built in wifi and a router at the ISP modem or ONT?
