JimM55's avatar
JimM55
RBR750 Satellite no longer reliably connecting to devices
My router model, according to the app, is RBR750 (which wasn't a choice in the pulldown list).
I installed the system about 10 months ago -- the router on one side of the first floor, a satellite on the other end of the house on the first floor and a satellite near my office on the second floor. It worked wonderfully well until about two weeks ago.
Now devices in my office (my Mac Mini, my iPad) keep dropping off of wi-fi, and when I check the network map in the app, it shows that devices usually aren't connecting to the nearby satellite but instead to the main router downstairs. (The whole reason I installed the mesh system is that devices in my office often dropped when all I had was a Nighthawk on the first floor.)  The app shows the satellite as online, but often no devices are connected (not always -- sometimes they are -- so it's not that the satellite is simply dead).
Any advice on what I might do?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling
     MM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • JimM55's avatar
      JimM55
      Firmware version: V4.6.3.7
      The modem is one provided by Verizon (FIOS).  I looked at it and couldn't find a model number.
      The house is about 2800 sq ft.  But its a solid masonry design, so that even though it's smaller than the house we lived in until last October, my old Nighthawk router could no longer reliably reach the farther parts of the house, hence the switch to the Orbi mesh system.  The satellites are 20 to 30 feet from the base router.  (The problem one is probably about 22 or so feet away.)  I checked the network map and both satellites get strong signal.
      Currently, the channels are set to:
         2.4GHz: Auto
         5 GHz: 48
      How do you specify multiple channels?  I tried both ctrl-click and shift-click on the pull-down menu, but it only selected one.
      As I noted, this setup was rock solid until a couple of weeks ago, when suddenly my Mac Mini, one room away from a satellite, suddenly started dropping from the wi-fi at various times. And when I looked at the network map, it wasn't usually connecting to the satellite next door, but to either the base router or the other satellite.  (This isn't always the case. Sometimes it does connect to the satellite, but not reliably, and I think it's when it tries to connect to the base instead that the Mac Mini has it's issues.)
      One final piece of info that may just be an anomoly: I just looked at the details of the satellite router. It showed Connection Type equal wired, which it isn't.  I checked the other satellite to compare, and it was listed as 5GHz. Then when I went back to the problem satellite, it was back to 5GHz.  This may just be a passing weirdness in the app, but I'm mentioning it in case it's indicating a possible issue.
      Thanks for your help.
      • FURRYe38's avatar
        The modem is one provided by Verizon (FIOS).  I looked at it and couldn't find a model number. <See if you can find a model# on the case unit.
        The house is about 2800 sq ft.  But its a solid masonry design, so that even though it's smaller than the house we lived in until last October, my old Nighthawk router could no longer reliably reach the farther parts of the house, hence the switch to the Orbi mesh system.  The satellites are 20 to 30 feet from the base router.  (The problem one is probably about 22 or so feet away.)  <22 feet is too close, 30 feet or more is recommended. I checked the network map and both satellites get strong signal.
           2.4GHz: Auto
           5 GHz: 48
        You can only select one channel at a time.
        Try following these settings:
        https://community.netgear.com/t5/Orbi-AX/New-RBK752-753-Firmware-Version-4-6-3-7-Released/m-p/2131914/highlight/true#M18742
