Joost2104
Jan 31, 2024Aspirant
RBR750 satellites disconnecting
Hi, I see more reported issues with disconnecting satellites in the community, but I have not been able to find the solution yet. Since a couple of months my satellites randomly disconnect fr...
Jan 31, 2024Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
️What channel configurations are currently set on the router?
- Joost2104Feb 01, 2024Aspirant
Hi,
Firmware RBR: V7.2.6.21_5.0.20
Firmware RBS: don't know, will check over the weekend.
Modem is a Genexis Hybrid Live! Titanium, in bridge mode. Firmware is managed by Internet provider.
CAT6 cable in place.
2 RBS deployed. RBR on ground floor, one RBS 1st floor and one RBS 2nd floor.
Size home is 3 floors, each floor 10 feet apart (height). Distance between RBR and RBS1 = ~15 feet and RBS1 to RBS 2 also ~15 feet.
Channel config: 2,4 GHz on auto, 5 GHz on 36. Not many WiFi neighbors, can only see network from next door.
- FURRYe38Feb 01, 2024Guru - Experienced User
What browser are you using? Is this seen with MS Edge, FireFox or Opera browsers?
"Distance between RBR and RBS1 = ~15 feet and RBS1 to RBS 2 also ~15 feet" This is TOO close to each to other. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Hi,
I use Google Chrome, and I observe the same in Edge and on the Orbi app (iPhone). Total size of the home is ~1900 sqft split over three floors.
I see the satellites connecting serially, so RBS1 to the RBR and RBS2 to RBS1. Are you suggsting that I decommission one RBS?
Best Joost.
