Joost2104
Jan 31, 2024Aspirant
RBR750 satellites disconnecting
Hi, I see more reported issues with disconnecting satellites in the community, but I have not been able to find the solution yet. Since a couple of months my satellites randomly disconnect fr...
Joost2104
Feb 01, 2024Aspirant
Hi,
Firmware RBR: V7.2.6.21_5.0.20
Firmware RBS: don't know, will check over the weekend.
Modem is a Genexis Hybrid Live! Titanium, in bridge mode. Firmware is managed by Internet provider.
CAT6 cable in place.
2 RBS deployed. RBR on ground floor, one RBS 1st floor and one RBS 2nd floor.
Size home is 3 floors, each floor 10 feet apart (height). Distance between RBR and RBS1 = ~15 feet and RBS1 to RBS 2 also ~15 feet.
Channel config: 2,4 GHz on auto, 5 GHz on 36. Not many WiFi neighbors, can only see network from next door.
Feb 01, 2024Guru - Experienced User
What browser are you using? Is this seen with MS Edge, FireFox or Opera browsers?
"Distance between RBR and RBS1 = ~15 feet and RBS1 to RBS 2 also ~15 feet" This is TOO close to each to other. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
