mike528
Jun 28, 2022Aspirant
RBR750 Sends Logs Constantly
Starting a few months back, my Orbi sends logs 5-10 times per days with only 11 lines of DHCP and UPnP events. I've tried different intervals and even turning it off from sending yesterday and receiv...
Jun 28, 2022Guru - Experienced User
What all do you have connected device wise?
Do you have all the logging options selected? Items that the RBR will track?
So disabling the email logging option is still seeing logs being sent?
Might try v.5 FW:
I'm on it now...I have email logs enabled and set for daily at 6AM, I do get additional logs in between, about 3-4.
mike528
I have about 20+ devices connected, PCs, phones, tablets, smart TVs, home automation devices,etc.
I currently have the second logs according to this schedule set to None. Include in Log is checked with everything other than Attempted access to allowed sites.
Thanks
- FURRYe38Jun 28, 2022Guru - Experienced User
Did you Disable the email logging fully by unchecking the Check box next to Enable Email Logging?
