WakaWaka22
Jan 28, 2021Aspirant
RBR750 Slow Upload Speed
Please help!! For whatever reason within the last week, I have lost all of my upload speed. Prior to this taking place, I was consistenly receiving more than 50mbps and recently it has been rang...
- Jan 28, 2021
Thank you!! Def was the firmware that needed to be updated. Ran a speed test and obtained 768 down and 35 up.
Jan 28, 2021Guru - Experienced User
I recommend manually downloading and manually updating to v12 which is more recent than the v22 version.
Review the release notes...
Use a wired PC or laptop and web browswer to apply the FW to the RBS first then RBR lastly.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- WakaWaka22Jan 28, 2021Aspirant
Thank you for the feedback. Will do the manual download and share back the results.
Our home is ~3,200 sq ft and the they are as close to 30ft apart as possible. Up until this past week, I have never had issues to date on the download / upload speed
- FURRYe38Jan 28, 2021Guru - Experienced User
Good to hear.
Enjoy. :smileyvery-happy:
