davstavros
May 13, 2022Aspirant
RBR750 Slow Upload
So I have just bought a 2 plack of RBR750 and the satellite. I also bought a TP-Link Archer A20 at the same time to test the two. The Archer arrived before the Orbi and I was able to set it up with ...
May 14, 2022Guru - Experienced User
What devices are you using to speed test with?
What speed test app are you using on the wired PC?
