mnicols74
Jun 12, 2022Aspirant
RBR750 slow wireless when connected to router - satellites fast
I have the following strange situation with my Netgear RBK750 mesh system: I have FiOS (1 Gbps down/1 Gbps down) and have an RBR750 with two satellites. I have the Orbi system running in AP m...
mnicols74
Jun 13, 2022Aspirant
Mikey94025,
Thanks for taking the time to take a look...answers below in italics.
- What is the device that you're testing with, e.g., an iPhone? Is this connected by 5Ghz or 2.4Ghz?
Have tested with multiple iphones on 5 ghz and multiple Windows laptops running Win 10 and Win 11.
- How are you measuring the speed, e.g., the speedtest phone app?
Ookla speedtest on the smartphones and laptop. Have also tested using other bandwidth test applications as well.
- Have you tried with a second device and are the results the same?
Results are the same with the different iphones and windows laptops.
- Have you tried changing the wireless channel to see if it affects the results (don't use Auto)?
I have - still remains the same.
- How is your wireless security configured, e.g., WPA2-PSK?
Yes. WPA2-PSK.
- What wireless settings have you changed from the Orbi defaults, e.g., WMM / Enable 20/40 MHz Coexistence / CTS/RTS Threshold / Preamble Mode
Initially I did not change any defaults. I compared everything to another Orbi Setup (RBR50) at my brother's home which doesn't have the problem and the only different was CTS/RTS. With the setup having the issue it was 64, at the other location it was 2347 so I switched it to that but no difference.
Mikey94025
Jun 13, 2022Hero
You seem to have tried everything correctly. I can't think of anything that would explain why your RBR wireless is slow but RBS wireless is fast.
When the RBR wireless connection is slow, what does the Windows wireless properties say about the link speed? That might be a clue for us. Press the Win key, search for "network connections", select View Network Connections, right-click on your Wireless adapter and select Status. Mine says 919.0 Mbps and I'm curious what yours says when you are observing only ~90 Mbps.
