Mikems
Jul 20, 2022Aspirant
RBR750 slow
I bought an RBR750 a few months ago and checked my speed from ORBI speed test. It shows 575 which is good since I have around 500. Then I ran several tests from the internet and they show under 200...
CrimpOn
Jul 20, 2022Guru - Experienced User
Please explain how you ran tests "from the internet". What device? What test?
In general, devices connected to the router over WiFi cannot achieve the same rate of speed as devices connected with Ethernet cable.
- MikemsJul 20, 2022Aspirant
I did run this with my phone connected to the wifi (orbi).
I used several different internet speeds tests and all tested about the same. I realize the wifi is going to be a little slow but it is more than 1/2 of the speed I am suppose to get.
- Mikey94025Jul 22, 2022Hero
Mikems wrote:I used several different internet speeds tests and all tested about the same. I realize the wifi is going to be a little slow but it is more than 1/2 of the speed I am suppose to get.
Wi-fi speeds are very limited depending upon your device and wireless band. The speeds will virtually always be a bit less than what your Orbi speed test is reporting (wired speeds, not wireless).
This site shows realistic top speeds for various wireless devices: https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi%2Ccomputers-wi-fi%2Ccomputers-ethernet-or-usb-adapter-to-ethernet. Don't worry if your wireless device speed test is near these max numbers.
Mobile devices (Wi-Fi)
Release date
802.11 version
Maximum possible speed
2020–present
802.11ax (Wi-Fi 6)
500 Mbps
2013–present
802.11ac
180 Mbps–390 Mbps
2011–2012
802.11n
90 Mbps
2007–2010
802.11n
32 Mbps–90 Mbps
2006 or earlier
802.11a/b/g
32 Mbps
Computers (Wi-Fi)
Release date
802.11 version
2020–present
802.11ax (Wi-Fi 6)
700 Mbps
2013–present
802.11ac
195 Mbps–585 Mbps
2011–2012
802.11n
180 Mbps–270 Mbps
2007–2010
802.11n
90 Mbps–180 Mbps
2006 or earlier
802.11a/b/g
32 Mbps
