Mikems
Jul 20, 2022Aspirant
RBR750 slow
I bought an RBR750 a few months ago and checked my speed from ORBI speed test. It shows 575 which is good since I have around 500. Then I ran several tests from the internet and they show under 200...
Jul 21, 2022Guru - Experienced User
What devices do you have connected?
Be sure to speed test with a wired PC connected to the RBR.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Mikems wrote:
I bought an RBR750 a few months ago and checked my speed from ORBI speed test. It shows 575 which is good since I have around 500. Then I ran several tests from the internet and they show under 200. Why is this so slow? What can I do? I purchased from Costco so I could return it?
