Mikems
Jul 20, 2022Aspirant
RBR750 slow
I bought an RBR750 a few months ago and checked my speed from ORBI speed test. It shows 575 which is good since I have around 500. Then I ran several tests from the internet and they show under 200...
Jul 29, 2022Guru - Experienced User
What devices do you have connected?
Be sure to speed test with a wired PC connected to the RBR.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Mikems
Jul 29, 2022Aspirant
It is not the modem it tests at 575mg. I have 500mg service. It is spectrum my service provider. I downloaded the latest firmware.
- FURRYe38Jul 29, 2022Guru - Experienced User
What specific Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What devices do you have connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
