Tylanner
Apr 07, 2023Aspirant
RBR750 Solid Magenta (no internet) after Xfinity Service Outage
I lost internet service during an Xfinity outage and my RBR750 system never came back online after the service outage. I use a personal DOCSIS 3.1 modem and my internet is fine when I am on LAN d...
- Apr 12, 2023Thanks for the help. My router system is now working.
My MAC address was re-assigned to my PC during my troubleshooting instead of my router after the outage when service came back. I assume xfinity only allows one device to have access at a time.
A combination of modem reset and xfinity “reset” resolved my issue…I did these steps multiple times but it is important to do them together and in specific sequences.
I think the issue can be avoided by not plugging your PC directly to the modem when the initial device assignment occurs.
Apr 07, 2023Guru - Experienced User
Which port on the CM modem is the RBR connected too. Be sure the RBR is the only wired device connected to the CM modem. RBR should be in port #1 and the other port should not be used. Can try swapping ports after you power cycle the CM modem off then back ON for 30 seconds.
All LEDs on the CM modem good? Should be green and Ethernet LED should be blinking green.
Tylanner
Tried LAN 1 and LAN 2 and no change.
Modem LEDs are good.
- FURRYe38Apr 07, 2023Guru - Experienced User
Try this, power OFF the CM modem and disconnect the RBR from the modem. Connect 1 ethernet PC to port 1 on the CM modem and power it on. After say 2-3 minutes, can the PC gain access to the internet?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- TylannerApr 07, 2023Aspirant
PC has internet access.
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Procedure Status Comment Acquire Downstream Channel 651000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 29 651000000 Hz -3.9 dBmV 38.8 dB 11590215 0 0 2 Locked QAM256 2 483000000 Hz -3.2 dBmV 39.8 dB 10220218 2 0 3 Locked QAM256 3 489000000 Hz -3.2 dBmV 39.7 dB 10209629 7 0 4 Locked QAM256 4 495000000 Hz -3.8 dBmV 39.7 dB 10212021 1 0 5 Locked QAM256 5 507000000 Hz -3.6 dBmV 39.5 dB 10230568 1 0 6 Locked QAM256 6 513000000 Hz -3.5 dBmV 39.6 dB 10233731 1 0 7 Locked QAM256 7 519000000 Hz -3.4 dBmV 39.8 dB 10238292 0 0 8 Locked QAM256 8 525000000 Hz -3.0 dBmV 39.8 dB 10242146 0 0 9 Locked QAM256 9 531000000 Hz -3.0 dBmV 39.6 dB 10245815 0 0 10 Locked QAM256 10 537000000 Hz -3.5 dBmV 39.5 dB 10249459 0 0 11 Locked QAM256 11 543000000 Hz -2.6 dBmV 39.5 dB 10253084 0 0 12 Locked QAM256 12 549000000 Hz -2.9 dBmV 39.7 dB 10257039 0 0 13 Locked QAM256 13 555000000 Hz -2.8 dBmV 39.8 dB 10260762 0 0 14 Locked QAM256 14 561000000 Hz -2.9 dBmV 39.5 dB 10264087 0 0 15 Locked QAM256 15 567000000 Hz -2.4 dBmV 39.6 dB 10267789 0 0 16 Locked QAM256 16 573000000 Hz -2.8 dBmV 39.6 dB 10272005 0 0 17 Locked QAM256 17 579000000 Hz -3.1 dBmV 39.4 dB 10275552 0 0 18 Locked QAM256 18 585000000 Hz -2.7 dBmV 39.5 dB 10279688 0 0 19 Locked QAM256 19 591000000 Hz -2.7 dBmV 39.3 dB 10283493 0 0 20 Locked QAM256 20 597000000 Hz -3.0 dBmV 39.5 dB 10287548 0 0 21 Locked QAM256 21 603000000 Hz -2.7 dBmV 39.6 dB 10291047 0 0 22 Locked QAM256 22 609000000 Hz -3.2 dBmV 39.3 dB 10294697 0 0 23 Locked QAM256 23 615000000 Hz -3.6 dBmV 39.3 dB 10298321 0 0 24 Locked QAM256 24 621000000 Hz -3.2 dBmV 39.2 dB 10302364 0 0 25 Locked QAM256 25 627000000 Hz -3.4 dBmV 39.3 dB 10306004 0 0 26 Locked QAM256 26 633000000 Hz -3.7 dBmV 39.4 dB 10271207 19706 18707 27 Locked QAM256 27 639000000 Hz -3.9 dBmV 39.2 dB 10245508 54806 25470 28 Locked QAM256 28 645000000 Hz -2.9 dBmV 38.0 dB 10328480 0 0 29 Locked QAM256 30 657000000 Hz -4.2 dBmV 39.2 dB 10315270 0 0 30 Locked QAM256 32 663000000 Hz -4.1 dBmV 39.0 dB 10287223 0 0 31 Locked QAM256 33 669000000 Hz -4.2 dBmV 39.0 dB 10288157 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35600000 Hz 55.8 dBmV 2 Locked ATDMA 2 29200000 Hz 56.0 dBmV 3 Locked ATDMA 3 22800000 Hz 57.5 dBmV 4 Locked ATDMA 4 16400000 Hz 58.8 dBmV 5 Locked ATDMA 5 39600000 Hz 52.8 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 31 722000000 Hz -4.2 dBmV 30.3 dB 1108 ~ 2987 6019030 5884973 0 2 Not Locked 0 0 0 Hz -0.6 dBmV 0.0 dB 0 ~ 4095 0 0 0 Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV 2023-04-07, 20:24:18 Error (4) SW upgrade Failed before download -TFTP Max Retry Exceeded 2023-04-07, 20:24:06 Notice (6) SW Download INIT - Via Config file d11_m_cm1100_extremepro_c01.cm 2023-04-07, 20:23:55 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:01:5c:ad:9a:80;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:01:5c:ad:9a:80;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:01:5c:ad:9a:80;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:01:5c:ad:9a:80;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:86:83:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Apr 07, 2023Guru - Experienced User
OK well if PC gets internet, shut down the modem and RBR, re-connect the RBR to the CM modem then power ON The modem and RBR. IF the RBR still fails to get connected and still has a front PINK LED, press the reset button in back of the RBR for 15 seconds then release. Walk thru the setup wizard on the RBR at 192.168.1.1 with the wired PC and web browser connected. Hopefully this will get the RBR working again...
Any Errors or Criticals seen on the Event logs page of the CM modem should be reviewed by the ISP and resolved.
