sks1234
Nov 09, 2025Aspirant
RBR750 speed cut in half with BGW320
I have searched the forum looking for a possible answer and have not found any good hits yet. I have my RBR750 directly connected to a BGW320-500 with cat6 and my download speed seems to get cut in h...
Teedoe
Nov 27, 2025Aspirant
Hi... I am having similar issues with my set up. I have the RBR750 along with the BGW320 as the modem. For WiFi I am not getting more than 180 mbps for both upload and download speeds on any of my devices. Even when I'm right next to the router.
I've tried both 2 and 3 methods and still same results.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Is there something that I am not doing to the modem correctly? The "configure the modems DMZ/ExposedHost" isn't something that I am familiar with doing. When I run speed tests to the modem it is getting 1000 mbps for both upload and download.
