jumpyg123's avatar
Feb 24, 2023
RBR750 speeds - Is this expected?
Hello,  I'm testing speeds around the house with my Pixel 7 phone using the Ookla Speedtest app.    Anyway, I was wondering if these speeds are good, and if upgrading to a newer model Orbi would p...
  • plemans's avatar
    Feb 24, 2023
    Those are pretty solid speeds.
    You might be able to get a little faster but I don't think your investment would be worth it because it'd cost quite a bit.
    Plus you really don't need faster speeds. Even streaming 4k only needs 25-40mbps. So if you're hitting upwards of 500mbps anywhere in your house, your speeds are plenty fast to do anything you need. You might see a benefit if you're doing a lot of massive file uploads but otherwise, its not the bottleneck in performance.
